Using handsfree calling
Using the Google voice assistant widget, you can ask your device to call a contact or phone number for you. The Google voice assistant allows you to use your device hands free.
- 1.
From the Home screen, tap the Assistant icon in the Google search widget.
Note: If prompted, read any Terms of Service disclaimers and tap Accept if you agree. Then, follow the onscreen prompts.
Step 1/3 - 2.
Speak "Call" followed by a contact's name or a phone number.
Note: If your request is understood, the phone will automatically place your call.
Step 2/3 - Step 3 of 3:
You've completed the steps!
Step 3/3
