Changing call settings
Learn how to change the call settings on your device. You may need to change the phone settings if you are roaming or if you want to turn Wi-Fi Calling on or off.
- 1.
From the Phone app, tap the Menu icon.
Step 1/5 - 2.
Tap Settings.
Step 2/5 - 3.
Tap More.
Step 3/5 - 4.
Select your preferences.
Step 4/5 - Step 5 of 5:
You've completed the steps!
Step 5/5
