Using the Notification panel
Alerts and notifications are displayed in the notification panel. Familiarize yourself with how to view and clear the notifications that you have received from your notification panel.
- 1.
Step 1/4 - 2.
To dismiss notifications individually, drag a notification to the left or right.
Note: Select a notification to view more information about it.
Step 2/4 - 3.
To dismiss all notifications, tap the Trash can icon.
Note: To close the Notification Panel, swipe from the left or right edge of the screen or swipe up on the screen.
Step 3/4 - Step 4 of 4:
You've completed the steps!
Step 4/4
