Setting up mobile hotspot
Set up your device as a Mobile Hotspot so you can share your data connection with other devices. Your device will create a Wi-Fi hotspot with its data connection. Other devices will be able to connect to the Wi-Fi hotspot.
Note: Use Mobile Hotspot to share your internet connection with other devices. You'll be charged for the data used by all devices connected to your hotspot.
- 1.
From the Home screen, tap Settings.
Step 1/8 - 2.
Tap Mobile network.
Step 2/8 - 3.
Tap Personal hotspot
Note: The configure screen lets you choose your device name and password.
Step 3/8 - 4.
Tap Password.
Step 4/8 - 5.
Enter your new password.
Step 5/8 - 6.
Tap OK.
Step 6/8 - 7.
Tap or slide the Personal hotspot switch to ON.
Step 7/8 - Step 8 of 8:
You've completed the steps!
Step 8/8
