Switching to Simple mode
Switch to Easy mode for simplified Home screens on your device. You will be able to switch back to standard mode if you choose to do so.
  1. Note: Simple mode gives you easy access to your favorite contacts, apps and settings in a simple format.
  2. Step 1/6
    From the Home screen, tap Settings.
  3. Step 2/6
    Scroll to System & updates.
  4. Step 3/6
    Tap System & updates.
  5. Step 4/6
    Tap Simple mode.
  6. Step 5/6
    Tap ENABLE.
  7. Step 6/6
    You've completed the steps!
Was this helpful?
