Accessing Simple Settings
Simple mode
Simple mode is a simple format that offers access to favorite contacts and commonly used apps and settings. It eliminates time spent setting up app shortcuts and widgets on the Home screen. You can switch back to Standard mode at any time.
You are still able to access all your device settings while in Easy Mode. The device settings will be laid out like they are in standard mode.
Note: The Easy Settings widget gives you quick access to some commonly changed settings, like ringtone, sound options and screen brightness.
- 1.
From the Home screen, tap Settings.
Note: Tap More settings on the next screen to control and adjust other functions such as, internet connections, phone security, display options and GPS.
Step 1/2 - Step 2 of 2:
You've completed the steps!
Step 2/2
