Accessing mobile network settings
When traveling internationally, your device settings may require an update to conserve data and minimize unwanted fees. Learn how to change roaming settings on your device ahead of your next international trip, including how to enable and disable roaming.
- 1.
From the Home screen, tap Settings.
Step 1/6 - 2.
Tap Mobile network.
Step 2/6 - 3.
Tap Mobile data.
Step 3/6 - 4.
Tap Preferred network mode.
Step 4/6 - 5.
Select your preferred network type.
Step 5/6 - Step 6 of 6:
You've completed the steps!
Step 6/6
