Pairing with a Bluetooth® device
Connect to other devices via Bluetooth to share media such as music or videos. Bluetooth devices can be anything from your stereo in your car to a keyboard to type on your mobile device with.
- Step 1/5
Note: The device you're pairing your phone with needs to be set to Pairing mode, or your phone won't be able to recognize it.
- Step 2/5
Touch and hold the Bluetooth icon.
- Step 3/5
Tap or slide the Bluetooth switch to ON.
Note: Your phone will automatically begin to scan for Bluetooth-ready devices.
- Step 4/5
Select the device you'd like to pair to.
Note: A password may be requested. Common manufacturer passwords are 0000 and 1234.
- Step 5/5Step 5 of 5:
You've completed the steps!
Was this tutorial helpful?
