Moto ZManaging the battery
Learn how to manage the battery on your device. Taking care of your battery will extend your battery life.
Current Step: 1 - From the Home screen, drag down the Notification Panel.
  1. 1 - From the Home screen, drag down the Notification Panel.
  2. 2 - Tap the Settings icon.
  3. 3 - Tap Battery.
  4. 4 - Tap USAGE DETAILS.
    • Note: From this screen, you can view details about how your battery power is being used.
  5. 5 - Tap the Back icon.
  6. 6 - Tap or slide the Battery saver switch to On.
    • Note: Battery saver mode saves battery power by reducing your device's performance.
  7. 7 - You've completed the steps!
1/7
