Skip to contentSkip to search
K4Changing Notification Sounds
You can personalize the sound your device makes when you receive a phone call, email, or text message.
Current Step: 1 - From the Home screen, drag down the Notification Panel.
  1. 1 - From the Home screen, drag down the Notification Panel.
  2. 2 - Tap the Settings icon.
  3. 3 - Tap Sound & notification.
  4. 4 - Tap Ringtone.
  5. 5 - Select a ringtone.
  6. 6 - Tap OK.
  7. 7 - Scroll to Vibration type.
  8. 8 - Tap Vibration type.
  9. 9 - Select a vibration pattern.
  10. 10 - Tap OK.
  11. 11 - You've completed the steps!
1/11
Answer Feedback Form
Was this information helpful?
