Skip to contentSkip to search
K4 2017Checking for and Installing System Updates
You can check for system updates on your device to make sure you are up to date with your software. Using the newest software can help keep your device healthy.
  2. 2 - Tap the Settings icon.
  3. 3 - Scroll to About phone.
  4. 4 - Tap About phone.
  5. 5 - Tap Update Center.
  6. 6 - Tap Software Update.
  7. 7 - Tap Check now for update. If necessary, follow the onscreen prompts to install the software update.
  8. 8 - You've completed the steps!
1/8
Answer Feedback Form
Was this information helpful?
