Using long press for communication
Apple iPhone X on iOS 15.4.0
Copy link
Use 3D Touch to quickly reply to a message. You can use this feature from the Lock Screen, Notification Panel, or on a notification popup at the top of your screen.
  1. Step 1/5
    From the Home screen, swipe to Contacts.
  2. Step 2/5
    Tap Contacts.
  3. Step 3/5
    Press and hold a contact.
  4. Step 4/5
    Select a communication option.
  5. Step 5/5
    Step 5 of 5:
    You've completed the steps!
Was this tutorial helpful?
