Turning on LED flash for alerts
Apple iPhone X on iOS 15.4.0
Copy link
You can turn on a notification LED light to visually alert you when you have notifications. This is useful if you are hearing impaired or if you have your device on silent often.
  1. Step 1/8
    From the Home screen, tap Settings.
  2. Step 2/8
    Scroll to Accessibility.
  3. Step 3/8
    Tap Accessibility.
  4. Step 4/8
    Scroll to Audio/Visual.
  5. Step 5/8
    Tap Audio/Visual.
  6. Step 6/8
    Scroll to LED Flash for Alerts.
  7. Step 7/8
    Tap or slide the LED Flash for Alerts switch to ON.
  8. Step 8/8
    Step 8 of 8:
    You've completed the steps!
Was this tutorial helpful?
