Using Control Center
Apple iPhone 6S Plus on iOS 15.4.0
Copy link
You have quick access to many of your device's features from your control center. Access your control center from the home screen and use it to do things like turn on or off the flashlight, start a time, access the calculator or camera, and more.
  1. Step 1/10
    From the Home screen, swipe up from the bottom of your screen.
  2. Step 2/10
    Tap the Flashlight icon to turn on your flashlight.
    The indicator is in the bottom left.
  3. Step 3/10
    Press and hold the Flashlight icon to view different brightness settings.
  4. Step 4/10
    Tap outside of the Brightness meter to return to the Control Center.
    The indicator is in the top left.
  5. Step 5/10
    Press and hold the Timer icon to view Timer quick settings.
  6. Step 6/10
    Tap outside of the Timer meter to return to the Control Center.
  7. Step 7/10
    Press and hold the Camera icon to view Camera shortcuts.
  8. Step 8/10
    Tap outside of the Camera shortcuts to return to the Control Center.
  9. Step 9/10
    Slide the Sound meter up or down to adjust iPhone volume.
  10. Step 10/10
    Step 10 of 10:
    You've completed the steps!
Was this tutorial helpful?
