iPhone 5SConfiguring LTE settings
Depending your device’s cellular capabilities, and what your carrier or cellular plan offers, your device can prioritize using 5G, LTE, or other networks. This is helpful if you want to maximize your speeds, ensure a consistent connection to a particular network, or reduce your overall data usage.
Current Step: 1 - From the Home screen, tap Settings.
Simultaneous voice and LTE data is available when using VoLTE. If your carrier, device, or network don't support VoLTE, you might use a reduced speed connection for data during voice calls. Contact your carrier for more information about your voice and data options.
  1. 1 - From the Home screen, tap Settings.
  2. 2 - Tap Cellular.
  3. 3 - Tap Cellular Data Options.
  4. 4 - Tap Enable LTE.
  5. 5 - Tap Off.
    • Note: This setting will disable LTE.
  6. 6 - Tap Data Only.
    • Note: This setting allows cellular data usage, but not voice calls over LTE.
  7. 7 - Tap Voice & Data.
    • Note: This setting allows voice calls and cellular data usage over LTE.
  8. 8 - Tap the Back icon to save your changes.
  9. 9 - You've completed the steps!
1/9
