iPhone 5SManaging the battery
Learn how to manage the battery on your device. Taking care of your battery will extend your battery life.
Current Step: 1 - From the Home screen, tap Settings.
  1. 1 - From the Home screen, tap Settings.
  2. 2 - Scroll to Battery.
  3. 3 - Tap Battery.
  4. 4 - Tap Battery Health.
    • Note: From this screen, you can view your battery's peak performance capability and relative capacity to when it was new.
  5. 5 - Tap Back.
    • Note: From the BATTERY USAGE section, you can view details about how your battery power is being used.
  6. 6 - Tap or slide the Low Power Mode switch to ON.
  7. 7 - You've completed the steps!
1/7
