iPhone 14 Pro MaxCreating a Custom Hiking/Walking Route
Create a custom downloadable hiking or walking route map to personalize your experience.
Current Step: 1 - From the maps app, tap Places, Guides, and Routes section.
  1. 1 - From the maps app, tap Places, Guides, and Routes section.
  2. 2 - Tap Routes.
  3. 3 - Tap Create Route.
    • Note: Here you can view you saved custom routes.
  4. 4 - Tap the map to add a point to the route.
  5. 5 - Select your preferences.
    • Note: From this screen, you can view distance and elevation of the created route.
  6. 6 - Tap Save.
  7. 7 - Tap Done.
    • Note: To have the route downloaded to use offline, tap the Download route switch to on. You can edit the name and include a note for the created route.
  8. 8 - You've completed the steps!
1/8
Answer Feedback Form
Was this information helpful?
