Skip to contentSkip to search
iPhone 12Turning on LED flash for alerts
You can turn on a notification LED light to visually alert you when you have notifications. This is useful if you are hearing impaired or if you have your device on silent often.
Current Step: 1 - From the Home screen, tap Settings.
  1. 1 - From the Home screen, tap Settings.
  2. 2 - Scroll to and tap Accessibility.
  3. 3 - Scroll to and tap Audio/Visual.
  4. 4 - Scroll to and tap LED Flash for Alerts
  5. 5 - Tap or slide the LED Flash for Alerts switch to ON.
1/6
Answer Feedback Form
Was this information helpful?
