Transferring content from your old device with a wireless connection
Samsung Galaxy XCover 4 on Android 9.0.0
Copy link
Using a weireless connection, you can use Smart Switch to move your pictures, videos, and other media files from your old device to your new device.
  1. Note: Before getting started, check to make sure your old device is supported by Smart Switch. You can find a full list here.
  2. Step 1/8
  3. Step 2/8
    Tap the Settings icon.
  4. Step 3/8
    Scroll to Accounts and backup
  5. Step 4/8
    Tap Accounts and backup.
  6. Step 5/8
    Tap Smart Switch.
  7. Step 6/8
    Tap Receive data.
  8. Step 7/8
    Tap Wireless.
    Note: After this step, select your old device type and follow the onscreen prompts to begin transferring your old content.
  9. Step 8/8
    Step 8 of 8:
    You've completed the steps!
Was this tutorial helpful?
