Transferring content from your old device with a USB connection
Samsung Galaxy XCover 4 on Android 9.0.0
Move your pictures, videos, and other media files from your old device to your new device using a USB cable.
Note: Before getting started, check to make sure your old device is supported by Smart Switch. You can find a full list here. You'll also need to make sure Smart Switch is installed on your old device and that the USB setting on your old device is set to transfer media files.
- Step 1/8
- Step 2/8
Tap the Settings icon.
- Step 3/8
Scroll to Accounts and backup
- Step 4/8
Tap Accounts and backup.
- Step 5/8
Tap Smart Switch.
- Step 6/8
Tap Receive data.
- Step 7/8
Tap Cable.
Note: After this step, follow the onscreen prompts to begin transferring your old content. Make sure to connect your old device to the USB cable first.
- Step 8/8
You've completed the steps!
Was this helpful?
