Configuring location settings
Samsung Galaxy XCover 4 on Android 9.0.0
  1. Step 1/8
  2. Step 2/8
    Tap the Settings icon.
  3. Step 3/8
    Scroll to Security.
  4. Step 4/8
    Tap Security.
  5. Step 5/8
    Scroll to Location.
  6. Step 6/8
    Tap Location.
  7. Step 7/8
    Tap or slide the Location switch to On.
    Note: If you turn Location Services off, you won't be able to use Google Maps, VZ Navigator or any other apps or features that require your location.
  8. Step 8/8
    You've completed the steps!
Was this helpful?
