Changing call settings
Samsung Galaxy XCover 4 on Android 9.0.0
Copy link
Learn how to change the call settings on your device. You may need to change the phone settings if you are roaming or if you want to turn Wi-Fi Calling on or off.
  1. Step 1/6
    From the Phone app, tap the Menu icon.
  2. Step 2/6
    Tap Settings.
  3. Step 3/6
    Scroll to Other call settings.
  4. Step 4/6
    Tap Other call settings.
  5. Step 5/6
    Select your preferences.
  6. Step 6/6
    Step 6 of 6:
    You've completed the steps!
Was this tutorial helpful?
