Galaxy S9Transferring content from your old device with a USB connection
Move your pictures, videos, and other media files from your old device to your new device using a USB cable.
Current Step: 1 - From the Home screen, swipe up to view your apps.
Before getting started, check to make sure your old device is supported by Smart Switch. You can find a full list <a href="https://www.samsung.com/us/support/owners/app/smart-switch" target="_blank">here</a>. You'll also need to make sure Smart Switch is installed on your old device and that the USB setting on your old device is set to transfer media files.
  1. 1 - From the Home screen, swipe up to view your apps.
  2. 2 - Tap Settings
  3. 3 - Scroll to Accounts and backup.
  4. 4 - Tap Accounts and backup.
  5. 5 - Tap Smart Switch.
  6. 6 - Tap Send data.
  7. 7 - Tap Cable.
    • Note: After this step, follow the onscreen prompts to begin transferring your old content. Make sure to connect your old device to the USB cable first.
  8. 8 - You've completed the steps!
1/8
