Galaxy S9+Changing roaming settings for a trip
When traveling internationally, you may want to turn data roaming on and off to conserve data and minimize unwanted fees.
Current Step: 1 - From the Home screen, swipe up to view your apps.
Roaming allows you to continue your data connection outside of your main coverage area. You can set access to Data Roaming while you're on a trip. You may have higher data charges if you're traveling outside of the coverage area.
  1. 1 - From the Home screen, swipe up to view your apps.
  2. 2 - Tap Settings
  3. 3 - Tap Connections.
  4. 4 - Tap Mobile networks.
  5. 5 - Tap or slide the Data roaming access switch to ON.
    • Remarque : Turning data roaming on allows you to connect to data services while roaming. Turn data roaming off to keep from incurring significant charges.
1/6
