Galaxy S8+Configuring location settings
  2. 2 - Tap the Settings icon.
  3. 3 - Tap Biometrics and security.
  4. 4 - Scroll to Location.
  5. 5 - Tap Location.
  6. 6 - Tap or slide the Location switch to On.
    • Note: If you turn Location Services off, you won't be able to use Google Maps or any other apps or features that require your location.
    • Note: You can also choose which apps will have access to your location.
  7. 7 - You've completed the steps!
1/7
