Galaxy S8+Using Bixby Vision
Using Bixby Vision, you can search the web by pointing your camera at an object. You will be able to click on a search option that will open with more details in the browser.
Current Step: 1 - From the Home Screen, tap the Camera icon.
  1. 1 - From the Home Screen, tap the Camera icon.
  2. 2 - Tap Bixby Vision.
  3. 3 - Point your camera at an object you'd like to search with Bixby Vision.
    • Note: In this tutorial, we are searching images with Bixby Vision, you can also search for product listings or translate text.
  4. 4 - Select a search option.
  5. 5 - You've completed the steps!
1/5
