Using Apps Edge
Samsung Galaxy S6 Edge on Android 7.0.0
Learn how to use Apps Edge on your device. The Apps edge displays your five most frequently used apps for you to access at a moment's notice. Add shortcuts to apps or functions you enjoy using most with your phone, such as taking selfies, creating new calendar events or sending a text.
- Step 1/11
From the Home screen, tap Apps.
- Step 2/11
Tap Settings.
- Step 3/11
Tap Display.
- Step 4/11
Scroll to Edge screen.
- Step 5/11
Tap Edge screen.
- Step 6/11
Tap Edge panels.
- Step 7/11
Tap EDIT beneath the Apps edge column. If neccessary, tap the Check mark to enable to People edge.
- Step 8/11
Tap and hold the App you'd like to add.
- Step 9/11
Drag an App to an empty space on the Edge screen panel.
- Step 10/11
Tap the Minus icon to remove an app from an Edge screen. Repeat these steps to add or delete more apps to the Edge screen.
- Step 11/11
You've completed the steps!
Was this helpful?
