Changing Call Settings
Samsung Galaxy S6 Edge on Android 7.0.0
Learn how to change the call settings on your device. You may need to change the phone settings if you are roaming or if you want to turn Wi-Fi Calling on or off.
- Step 1/7
From the Phone app, tap the Menu icon.
- Step 2/7
Tap Settings.
- Step 3/7
Tap Ringtones and keypad tones.
- Step 4/7
Tap Ringtones.
- Step 5/7
Select a ringtone.
- Step 6/7
Tap the Back button to save your changes.
- Step 7/7Step 7 of 7:
You've completed the steps!
Was this helpful?
