Resetting Network Settings
Samsung Galaxy S6 Edge on Android 7.0.0
Copy link
If you are having trouble connecting to the Internet you may need to reset your network connections. Resetting your network connections will disconnect any Bluetooth devices connected to your device and disconnect your device from any Wi-Fi networks it is connected to.
  1. Step 1/9
  2. Step 2/9
    Tap the Settings icon.
  3. Step 3/9
    Scroll to General management.
  4. Step 4/9
    Tap General management.
    The indicator is towards the left.
  5. Step 5/9
    Tap Reset.
  6. Step 6/9
    Tap Reset network settings.
  7. Step 7/9
    Tap RESET SETTINGS.
  8. Step 8/9
    Tap RESET SETTINGS again.
  9. Step 9/9
    Step 9 of 9:
    You've completed the steps!
Was this tutorial helpful?
