Using a Fingerprint Lock
Samsung Galaxy S6 Edge on Android 7.0.0
Copy link
You can set up your device to unlock by using your fingerprint. When this lock type is set up you can place your the finger you used to set up the lock on the fingerprint sensor to unlock your device.
  1. Step 1/13
  2. Step 2/13
    Tap the Settings icon.
  3. Step 3/13
    Scroll to Lock screen and security.
  4. Step 4/13
    Tap Lock screen and security.
    The indicator is in the top left.
  5. Step 5/13
    Tap Screen lock type.
  6. Step 6/13
    Tap Fingerprints.
  7. Step 7/13
    Select a backup screen lock.
  8. Step 8/13
    Enter your backup screen lock.
  9. Step 9/13
    Tap CONTINUE.
  10. Step 10/13
    Confirm your backup screen lock.
  11. Step 11/13
    Tap CONFIRM.
  12. Step 12/13
    Follow the prompts to set up your fingerprint.
  13. Step 13/13
    Step 13 of 13:
    You've completed the steps!
Was this tutorial helpful?
