Galaxy S6 Edge PlusRestarting your device
Restarting your device is often one of the first steps when troubleshooting a device issue.
If you’re having problems with your device, turn your phone off and on again (known as a soft reset).
  2. 2 - Drag down the Quick Settings panel.
  3. 3 - Tap the Power icon.
    • Note: You can also access Power Options by pressing and holding the Side and Volume down buttons simultaneously.
  4. 4 - Tap Restart.
  5. 5 - Tap Restart again.
1/6
