Setting the Phone to Silent
Samsung Galaxy S6 Edge Plus on Android 7.0.0
Silent mode will quiet your device's notifications. When your device is in silent mode, it will not make a sound to notify you of incoming notifications. You can set it to vibrate to alert you to incoming notifications with vibrations instead of sound.
- 1.
Step 1/5 - 2.
Drag down the Quick settings panel.
Step 2/5 - 3.
Tap the Sound icon.
Step 3/5 - 4.
Tap the Vibrate icon.
Step 4/5 - Step 5 of 5:
You've completed the steps!
Step 5/5
