Using a Fingerprint Lock
Samsung Galaxy S6 Edge Plus on Android 7.0.0
You can set up your device to unlock by using your fingerprint. When this lock type is set up you can place your the finger you used to set up the lock on the fingerprint sensor to unlock your device.
  1. Step 1/12
  2. Step 2/12
    Tap the Settings icon.
  3. Step 3/12
    Tap Lock screen and security.
    The indicator is in the bottom left.
  4. Step 4/12
    Tap Screen lock type.
  5. Step 5/12
    Tap Fingerprints.
  6. Step 6/12
    Select a backup screen lock.
  7. Step 7/12
    Enter your backup screen lock.
  8. Step 8/12
    Tap CONTINUE.
  9. Step 9/12
    Confirm your backup screen lock.
  10. Step 10/12
    Tap CONFIRM.
  11. Step 11/12
    Follow the prompts to set up your fingerprint.
  12. Step 12/12
    Step 12 of 12:
    You've completed the steps!
Was this helpful?
