Charging Your Device
Samsung Galaxy S6 Edge Plus on Android 7.0.0
You can charge your device with its included cable and adapter, a third-party cable and adapter, or wirelessly (if your device supports it).
- 1.
Locate the USB charging port on your device.
Step 1/4 - 2.
Insert the USB cable into your device.
Step 2/4 - 3.
When your device is finished charging, remove the USB cable.
Step 3/4 - Step 4 of 4:
You've completed the steps!
Step 4/4
