Skip to contentSkip to search
Galaxy S24 UltraChanging call settings
Learn how to change the call settings on your device. You may need to change the phone settings if you are roaming or if you want to turn Wi-Fi Calling on or off.
Current Step: 1 - From the Phone app, tap the Menu icon.
  1. 1 - From the Phone app, tap the Menu icon.
  2. 2 - Tap Settings.
  3. 3 - Scroll to and tap Other call settings.
  4. 4 - Select your preferences.
  5. 5 - You've completed the steps!
1/5
Answer Feedback Form
Was this information helpful?
