Transferring content from your old device with a USB connection
Samsung Galaxy Note9 on Android 10.0.0
Move your pictures, videos, and other media files from your old device to your new device using a USB cable.
Note: Before getting started, check to make sure your old device is supported by Smart Switch. You can find a full list here. You'll also need to make sure Smart Switch is installed on your old device and that the USB setting on your old device is set to transfer media files.
- 1.
From the Home screen, swipe up to view your apps.
Step 1/8 - 2.
Tap Settings
Step 2/8 - 3.
Scroll to Accounts and backup.
Step 3/8 - 4.
Tap Accounts and backup.
Step 4/8 - 5.
Tap Smart Switch.
Step 5/8 - 6.
Tap Send data.
Step 6/8 - 7.
Tap Cable.
Note: After this step, follow the onscreen prompts to begin transferring your old content. Make sure to connect your old device to the USB cable first.
Step 7/8 - Step 8 of 8:
You've completed the steps!
Step 8/8
