Setting the phone to silent
Samsung Galaxy Note9 on Android 10.0.0
Silent mode will quiet your device's notifications. When your device is in silent mode, it will not make a sound to notify you of incoming notifications. You can set it to vibrate to alert you to incoming notifications with vibrations instead of sound.
- Step 1/4
- Step 2/4
Tap the Sound icon to set your phone to vibrate only.
- Step 3/4
Tap the Vibrate icon to set your phone to silent.
Note: You can also use the Volume buttons to lower the volume to silent.
- Step 4/4
You've completed the steps!
Was this helpful?
