Finding additional help
Samsung Galaxy Note9 on Android 10.0.0
You can use your device's help documents to find more help or information for your device.
  1. Step 1/5
    From the Home screen, swipe up to view your apps.
  2. Step 2/5
    Tap Settings.
    The indicator is towards the left.
  3. Step 3/5
    Scroll to Tips and user manual.
  4. Step 4/5
    Tap Tips and user manual.
    Note: After this step, you'll find videos and tutorials to help you get the most out of your device.
  5. Step 5/5
    You've completed the steps!
Was this helpful?
