Galaxy Note8Managing the battery
Learn how to manage the battery on your device. Taking care of your battery will extend your battery life.
  2. 2 - Tap the Settings icon.
  3. 3 - Scroll to Device care.
  4. 4 - Tap Device care.
  5. 5 - Tap Battery.
  6. 6 - Tap Battery Usage.
    • Note: From this screen, you can view details about how your battery power is being used.
  7. 7 - Select an app to view more information.
  8. 8 - Tap the Back icon.
  9. 9 - Tap the Back icon again.
  10. 10 - Tap the Menu icon.
  11. 11 - Tap Settings.
  12. 12 - Tap Optimize settings.
  13. 13 - Tap or slide the Optimize settings switch to ON.
    • Note: Power saving mode saves battery power by limiting access to certain apps, including the flashlight.
  14. 14 - You've completed the steps!
1/14
