Changing general settings
Samsung Galaxy J3 Prime on Android 8.1.0
Copy link
Changing the General Settings in Gmail will change the settings for all email accounts that have been added to Gmail.
  1. Step 1/6
    From the Gmail app main screen, tap the Navigation icon.
    The indicator is in the top left.
  2. Step 2/6
    Scroll to Settings.
  3. Step 3/6
    Tap Settings.
    The indicator is in the bottom left.
  4. Step 4/6
    Tap General settings.
    Note: From this screen, you can adjust your inbox actions and notification preferences.
  5. Step 5/6
    Select your preferences.
  6. Step 6/6
    Step 6 of 6:
    You've completed the steps!
Was this tutorial helpful?
