G7 ThinQAdding and changing a Lock screen shortcut
Some apps can be accessed quickly from your lock screen. You can change the apps that appear on the lock screen for quick access.
Current Step: 1 - From the Home screen, tap the Settings icon.
  1. 1 - From the Home screen, tap the Settings icon.
  2. 2 - Tap Lock screen & security.
  3. 3 - Tap Customize Lock screen.
  4. 4 - Tap Shortcuts.
  5. 5 - Select the shortcut you'd like to change.
    • Remarque : You can also add a new shortcut by tapping Add.
  6. 6 - Select your preferred new shortcut.
  7. 7 - You've completed the steps!
1/7
