G7 ThinQUsing power saving mode
Use emergency power saving mode when your device is low on battery and you still need to be able use some functions on your device.
Current Step: 1 - From the Home screen, drag down the Notification Panel.
Battery running low? Check out our batteries, chargers, adapters and cables.
  1. 1 - From the Home screen, drag down the Notification Panel.
    • Note: Power saving mode saves battery power by limiting access to certain apps, including the flashlight. You can also send your location or a text message to an emergency contact.
  2. 2 - Drag down the Quick Settings panel.
  3. 3 - Tap Battery saver.
  4. 4 - Tap Turn on.
  5. 5 - You've completed the steps!
1/5
