PhoneSetting the phone to silent
When your device is in do not disturb or silent mode, it will not make a sound to notify you of incoming notifications.
  2. 2 - Drag down the Quick settings panel.
  3. 3 - Tap the Do Not Disturb icon to set your phone to silent.
    • Remarque : You can also use the Volume buttons to lower the volume to silent.
  4. 4 - You've completed the steps!
1/4
