PhoneUsing power saving mode
Use emergency power saving mode when your device is low on battery and you still need to be able use some functions on your device.
  2. 2 - Drag down the Quick settings panel.
  3. 3 - Tap the Settings icon.
  4. 4 - Tap Battery.
  5. 5 - Tap Battery Saver.
  6. 6 - Tap TURN ON NOW.
    • Remarque : Battery saving mode saves battery power by limiting access to certain apps.
  7. 7 - You've completed the steps!
1/7
