TELUS​ ​Boost​ ​Wi-Fi​ ​Quick​ ​Start​ ​Guide
Learn more about TELUS Boost Wi-Fi
Please find below information for:
TELUS Boost Wi-Fi Quick Start Guide
LED Status Light Help
Solid blue
Your Wi-Fi booster has a good Wi-Fi or ethernet connection.
Flashing blue
Your Wi-Fi booster is connecting to your home network.
Solid purple
Your Wi-Fi booster is starting. It may take up to two minutes for your Wi-Fi booster to turn on. This process is complete once the LED is a solid blue.
Flashing purple
Your Wi-Fi booster software is updating. Do not turn off your Wi-Fi booster during this time.
Amber
Your Wi-Fi booster is working, but moving it closer to the Wi-Fi booster that is connected to your modem could optimize performance.
Red
Your Wi-Fi booster is not connected to the network. If it is the Wi-Fi booster connected to your modem, check the ethernet connection. If it is located elsewhere in your home, try moving it closer to the Wi-Fi booster that is connected to your modem.
Installation Tips
  • To install your starter pack Wi-Fi boosters* and manage your TELUS Boost Wi-Fi, use your device’s app store to search for and download the TELUS My Wi-Fi app
    Note: If you are downloading the app on an iPad and cannot find it in the app store, you may need to select the iPhone only option at the top left of the app store screen.
  • Your first Wi-Fi booster should be connected to your modem using the ethernet cord provided
  • Once the light on your first Wi-Fi booster turns a solid blue, the My Wi-Fi app will guide you through steps to connect to it, enter the admin password, and set the Wi-Fi booster’s location
  • To ensure you are using your TELUS Boost Wi-Fi network, follow the My Wi-Fi app instructions to forget your old network
*To learn how to install a third (or more) Wi-Fi booster, use the Expansion Pack Quick Start Guide.
Location Tips
Following the TELUS My Wi-Fi app instructions will help you determine good locations for your Wi-Fi boosters.
  • To optimize coverage, pick a location halfway between your modem and an area of poor or no signal
  • Use the app’s location tester to determine the area is in a good position
  • Below is an example of an optimally-covered home:
Expansion Pack for TELUS Boost Wi-Fi Quick Start Guide
Solid blue
Flashing blue
Solid purple
Flashing purple
Amber
Red
Installation Tips
  1. To install and manage your TELUS Boost Wi-Fi, use your device’s app store to search for and download the TELUS My Wi-Fi app
    Note: If you are downloading the app on an iPad and cannot find it in the app store, you may need to select the iPhone Only option at the top left of the app store screen.
  2. Ensure that you have installed your previous TELUS Wi-Fi boosters from the Starter Pack. The My Wi-Fi app will guide you through this installation process
  3. From the top menu of the app, go to Settings and select Add another Wi-Fi booster
  4. Without unplugging your first Wi-Fi booster, connect your new Wi-Fi booster to your modem using the ethernet cable provided. If your modem has no vacant spots, you may temporarily disconnect one non-Boost connection to enable the Boost install
  5. Wait until the LED light to turn from solid purple, to flashing blue, to flashing purple, to solid blue. This may take up to five minutes
    Note: This step transfers your existing Boost Wi-Fi network settings to your new Wi-Fi booster.
  6. Once the LED light on your new Wi-Fi booster turns solid blue, follow the My Wi-Fi app steps to determine a suitable location for your Wi-Fi booster. The TELUS My Wi-Fi app instructions will help you do the following:
  7. Once your new Wi-Fi booster is installed, it will appear on your My Wi-Fi app’s home and network screens
  8. Repeat steps 3-7 for each additional Wi-Fi booster you install
Did this solve your issue?
Yes No
Please do let us know, we're updating support articles all the time.
Thank you for your feedback
Why didn't this content help?
How can we improve the content of this article?
Remaining characters: 250
Other ways to get support
