Learn how to use the ADC-S40-T temperature sensor, replace the battery, panel/module compatibility and more.
Panel type | Minimum version |
2GIG EDGE | All panel versions |
2GIG GoControl/GC2/GC2e | Panel version 1.13 |
2GIG GC3/GC3e | Panel version 3.0.1 |
DSC PowerSeries Neo | Module version 185e |
DSC Impassa | Module version 1.3 |
Interlogix Simon XT / XTi | Module version 185b |
Interlogix NX | Module version 185a |
Interlogix Concord | Module version 185b |
Qolsys IQ / DSC Touch | Incompatible |
Qolsys IQ Panel 2 | Panel version 2.0.0 |
Qolsys IQ Hub/IQ Panel 4/IQ4 Hub/IQ Pro/IQ4 NS | All panel versions |
SEM - Honeywell/ADEMCO Vista | SEM version 187 |
SEM - DSC PowerSeries | SEM version 185a |
Alarm.com Hub/B36 Hub/PC Hub 2.0 | Hub version 185c |
