Add a Chamberlain LiftMaster MyQ® Smart Garage Hub (821LMB) to your TELUS SmartHome
Adding a Chamberlain LiftMaster MyQ® Smart Garage Hub (821LMB) to your home will allow you to integrate a wide range of garage door openers with your TELUS SmartHome Security system.
To add your Chamberlain LiftMaster MyQ® Smart Garage Hub (821LMB) to your TELUS SmartHome Security system, follow these simple steps:
- Before you start, ensure your MyQ® Garage is not registered through your MyQ®/Liftmaster/Chamberlain or other similar apps
- Verify the LED on the Hub is solid green before registering through the TELUS SmartHome Security system web portal
- Log into the web portal using your login credentials
- In the left navigation bar, select Settings
- Select Managed Devices
- Select Add Devices in the top-right corner of the screen
- Select Garage Door
- Select your device that matches the image and device name in the drop-down list and select Next
- Select Register Gateway
- Open or close your garage door using the wall control switch
- In the Serial Number field, enter the serial number found on the back of your device and select Continue
Note: Upon successful pairing, you will see a confirmation message at the top of the screen that your device has been added successfully.
- Select Garage Door again
- Choose the device previously selected and select Next
- Select Add Device and select Next
- Select one of the supported options to link to your device:
To link to a Wall Panel:
- Select MyQ Wall Panel
- Locate the Learn button on the wall control
- Press the Learn button twice to pair your wall control. The red LED on the control panel will light up once pairing has been initiated
To link a Garage Door Opener:
- Select MyQ Garage Opener
- Locate the Learn button on the garage door opener. This button can typically be found close to the wiring ports on the garage door opener
- Press and hold the Learn button for 2 seconds to initiate pairing. The Learn LED on the garage door opener will light up once pairing has been initiated
Important: Do not hold the Learn button down for more than 6 seconds as this will erase all current devices from the opener’s memory.
- Select Check for New Devices and follow the onscreen instructions to complete the pairing
- To link another supported option to your device or if pairing is unsuccessful, please repeat steps 12-16
Notes:
- This device will require sufficient Wi-Fi signal in your garage. To expand your Wi-Fi coverage to every corner of your home, get the TELUS Boost Wi-Fi Starter Pack. TELUS Internet required
- TELUS does not provide support for these devices. For additional support, contact your device manufacturer or local retailer
