Internet speed test for TELUS Business customers
Measure the speed of your Internet connection and get information on factors that impact your speed.
Before you run a speed test
: For the most accurate results, it’s best to run this test on a desktop or laptop computer that is connected to your modem with an Ethernet cable. If that’s not possible, and you can only connect via Wi-Fi, place the device you’re running the test on in an unobstructed area within two metres of the modem/access point and try again. It also helps to pause any large downloads or video streaming in your business.
Check your internet speed with our advanced speed test tool
Yes
No
Related articles
Follow these tips and suggestions if you're experiencing a slow internet connection.
How to find and reboot your modem
We’re sorry that you’re experiencing Internet connection issues. Here are some troubleshooting steps to help get your services back online.
Get the most from your TELUS Business Wi-Fi
Learn more about TELUS Boost Wi-Fi 6 and find answers to common Wi-Fi questions.
