Network Reference Guide - TELUS Business Connect
Technical Network guides for your Business Connect
Internet Requirements
Table 2. End-to-End Network Path Performance Requirements
Network Property
Requirement
Link Capacity
Each link in the end-to-end path must have symmetric (bidirectional) capacity which is larger than the maximum number of simultaneous calls plus capacity added for other types of non-real-time traffic and growth (Tables T.2 & T.3)
Delay
< 150 ms (of one way latency)*
Packet Loss
< 1%
Jitter
< 30 ms
Bandwidth - Hard Phones and VoIP Apps
Table T.2 - Business Connect Desk, Conference and Cordless Phone and VoIP App - Transmit and Receive Bandwidth
Endpoint
Codec
Transmit and Receive Bandwidth (Kbps)
Desk phone and IP Conference phone
G.711
87
G.729
31
G.722
87
Opus
60 - 80
Video*
616
Desktop or mobile VoIP App component
Opus
60 - 80
Bandwidth - Business Connect Video
Table T.3 - Business Connect Video - Transmit and Receive Bandwidth
Use Case
Transmit Bandwidth (Kbps)
Group video conference call (>10 participants)
1750
4000
Group video conference call (3-10 participants)
2250
6100
2-party video call
3550
2090
Group audio-only conference call
70 - 100
70 - 100
Business Connect IP Supernets
Test Server
(does not de-prioritize pings):
199.255.120.184
Table 3. Business Connect IP Supernets
66.81.240.0/20
80.81.128.0/20
103.44.68.0/22
104.245.56.0/21
185.23.248.0/22
192.209.24.0/21
199.68.212.0/22
199.255.120.0/22
208.87.40.0/22
Functions to Disable
Table 4. Functions which may impair SIP signaling and/or RTP media traffic
Layer
Function
Application
• SIP Application Layer Gateway (SIP ALG), also referred to as SIP Transformations
• Deep Packet Inspection (DPI)
• Application Layer Access Control
• Stateful Packet Inspection (SPI), also called Dynamic Packet Filtering
• Intrusion Detection/Intrusion Prevention System (IDS/IPS)
• Web Proxy operation
• WAN Acceleration
Transport
• Port filtering
IP
• Packet-by-packet load balancing across multiple Service Providers links
IP & Data Link
• Auto-QoS, when used in combination with Polycom/Poly phones
• Dynamic ARP Inspection
Physical
• Energy Efficient Ethernet (a.k.a. Green Ethernet)
• Satellite (Ethernet over microwave) network connections
Domains to Whitelist
Table 5. Whitelisting of Domains and IP Addresses
Purpose
Cloud Service
Domain Name / IP Address (To be whitelisted)
Destination Ports (To be whitelisted)
Business Connect Website
Information & Support
www.telus.com/businessconnect www.telus.com/business/support/topic/phone/   business-connect-voip
TCP\443
Voice Manager (Online Portal)
Login Page
voicemanager.businessconnect.telus.com
TCP\443
Analytics
Dashboard
analytics.businessconnect.telus.com             35.190.70.192
TCP\443
Softphone Archiver
Secure File Transfer
For archiving to an enterprise SFTP server, the following SFTP client IP addresses in the Business Connect cloud need to be whitelisted:
TCP\22
34.225.218.68, 34.226.29.169, 34.234.210.244, 34.236.210.8, 34.239.13.99, 35.172.123.110, 52.87.7.127, 54.80.51.95
Any of these IP addresses may dynamically be selected by the Business Connect SFTP client to connect to an enterprise SFTP server.
Business Connect App
App
app.businessconnect.telus.com
TCP\443
Login Page
video.businessconnect.telus.com
See Table B.6 - TCP\443
Desktop Softphone Application & Mobile Application
Presence Status, Call Log Notifications, and Voicemail notifications
.pubnub.com*
TCP\443
.pubnub.net*
.pndsn.com*
ringcentral.pubnubapi.com (for newer endpoint versions)
Google Chrome Extension
Login Page
account.google.com
TCP\443
Chrome APIs for plugin
apis.google.com
Fonts used by Google Chrome
fonts.gstatic.com
SIP Proxy Server
SIP Registration
.ringcentral.com*
If the proxy/firewall server cannot handle wildcards, then use the signaling ports TCP\5090-5099 and media ports UDP\20000-64999 in combination with the supernets indicated in Table 3
Soft Clients
Software and Provisioning
.cloudfront.net*
TCP\443
Polycom/Poly Desk Phones and Conference Phones
Provisioning
pp.ringcentral.com
TCP\443
Firmware Update
pp.s3.ringcentral.com
Cisco Desk Phones
Provisioning and firmware update
cp.ringcentral.com
TCP\443
Yealink Desk Phones
yp.ringcentral.com
TCP\443
DSCP Values & Traffic Shaping
Table 6. Traffic Types and Classification
Traffic Class
CoS Decimal Value (Layer 2)
DSCP Decimal Value (Layer 3)
Name (Layer 3)
Drop Probability (Layer 3)
VoIP Media - Real Time
5
46
EF
N/A
Video Media - Real Time
4
34
AF41
Low
SIP
3
26
AF31
Low
Transactional:
2
18
AF21
Low
• Network Time Service
• Mobile App Data Sync
• LDAP Directory Service
Best Effort: Phone Provisioning and firmware update
0
0
BE
Undetermined
Table 7. Traffic Types and Classification
Traffic Class
Name (Layer 3)
5
46
EF
N/A
Video Media - Real Time SIP
Transactional:
0
0
BE
Undetermined
• Best Effort: Phone Provisioning and firmware update
Port Ranges & Protocols
Table B.1 - Desk, Conference and Cordless Phone
Traffic Type
Application Protocol
Destination Ports
Media
RTP
UDP\20000-64999
Media - Secured
SRTP
UDP\20000-64999
Signaling
SIP
TCP\5090, TCP\5099**, UDP\5090
Signaling - Secured
SIP/TLS
TCP\5096, TCP\5098**
NTP
UDP\123
LDAP/(TLS/SSL)
TCP\636
Provisioning
HTTP and HTTPS
TCP\443
** Ports 5098 and 5099 only need to be opened for Busy Lamp Appearance when
line sharing
is used.
Table B.2 - Desktop Softphone Application
Traffic Type
Destination Ports
Media
RTP
UDP\20000-64999
Media - Secured
SRTP
UDP\20000-64999
Signaling
SIP
TCP\5091
Signaling - Secured
SIP/TLS
TCP\5097
LDAP/(TLS/SSL)
TCP\636
Provisioning and Presence Status
HTTP and HTTPS
TCP\80 and TCP\443
Table B.3 - iOS and Android Mobile Phone Application (on Wi-Fi Network)
The following is the specific ports usage, but it's recommended to open the port range 5090-5099 for UDP/TCP/TLS because new ports may be added and some ports configuration may be changed within this range.
Traffic Type
Destination Ports
Media
RTP
UDP\20000-64999
Media - Secured
SRTP
UDP\20000-64999
Signaling
SIP
UDP\5090 and UDP\5091
TCP\5090 and TCP\5091
Signaling (IPv6 client)
SIP/WSS/TLS
TCP\5090-5098
TCP\8085-8090
Signaling - Secured
SIP/WSS/TLS
TCP\5097
TCP\8085-8090
Mobile App Data Sync with Business Connect backend (e.g., call log info, presence, and voicemails)
HTTPS
TCP\443
LDAP
TCP\636
HTTP and HTTPS
TCP\80 and TCP\443
Table B.5 - WebRTC Telephony (Chrome Extension, Business Connect PC App)
Traffic Type
Destination Ports
Media
UDP\20000-64999
Signaling
TCP\8083
LDAP/TLS
TCP\636 and TCP\3269
Presence Status
TCP\6182
Access Control
STUN
UDP\19302
Table B.6 - Business Connect Video - Desktop Client and Chrome Browser
Traffic Type
Destination Ports
Media - Secured
SRTP
UDP\10000-19999 (default)
SRTP
TCP\443 (if UDP is not available)
Signaling - Secured
HTTPS/WSS/TLS
TCP\443
Yes
No
Related articles
This Privacy Statement describes how TELUS collects, uses, and discloses your personal information when you use the TELUS Business Connect Mobile App.
