Wireless settings
Create up to four dedicated networks with TELUS Business Wi-Fi
The TELUS technician who installs your Business WiFi service will
configure a password for encrypted dedicated Private and Guest networks (up to 4).
Enable or disable a dedicated network
Select
Network
and
Wireless Settings
from the
left navigation bar
Select the
SSID
from the dropdown menu, choose either
Enabled or Disabled
and hit
Save Changes.
When the network is disabled, your users will be unable to detect it or connect to it. If your encryption setting is left Open (no encryption), users will not be required to enter a password when accessing your network.
Select the desired network in the SSID drop-down menu.
Select
Encrypted with password
and enter the password of your choice.
Choose a WPA2 (recommended) or WEP password and hit
Save changes.
When the
option is selected, your users will be required to enter the password prior to connecting to the network.
If you need to add or edit a password following the installation, you can do so by selecting
Network
and
Wireless Settings
in your dashboard or by calling Customer Support at 1-888-611-9988.
